I recently upgraded my home security setup with the EZ Motion 3-in-1 sensor, and I wanted to share my experience with the community. After some initial challenges, I managed to get it working seamlessly with my smart lighting system. Here’s how I did it:
The Challenge:
At first, I struggled with getting the sensor to trigger my lights only when the room was dark. I tried direct associations and scenes, but nothing worked as expected. The lights would either stay on too long or not activate at all. I was about to give up until I found the solution!
The Solution:
I discovered that adjusting the Light Threshold to 40% was the key. By setting this value, the sensor now reliably activates the lights only when the room is below 40% brightness. Pairing this with a simple Lua script ensured that the lights only turn on when motion is detected in low-light conditions.
Tips for Others:
- Location Matters: Place your motion sensor at the right height and angle to avoid false triggers.
- Test Scenes: Always test your scenes in different lighting conditions to ensure they work as intended.
- Adjust Thresholds: Don’t be afraid to experiment with the light threshold settings to find the perfect balance.
The Outcome:
Now, my living room is perfectly lit when I walk in after dark, and the lights turn off automatically when the room is empty. It’s a small change that makes a big difference in daily convenience!
If anyone else is struggling with motion sensor integration, feel free to reach out. I’d love to help others achieve the same success! ![]()
