Smart Phone Charging Automation: A Comprehensive Guide
I recently stumbled upon an innovative solution for managing smartphone charging through Home Assistant, and I wanted to share my experience with the community. This automation not only prevents overcharging but also optimizes energy usage by scheduling charging during specific times. Here’s how it works:
The Problem:
Smartphones often charge to 100% even when it’s unnecessary, which can slightly reduce battery longevity. Leaving a phone plugged in overnight can lead to constant charging cycles, even when the battery is already full.
The Solution:
An automation blueprint created by XpycTee addresses this issue perfectly. It automatically manages charging by turning a smart plug on or off based on the phone’s battery level and a defined schedule. Here’s a breakdown of its features:
  • Turn On: The smart plug activates when the battery drops below a user-defined minimum (e.g., 20%).
  • Scheduled Charging: During a specified time window (e.g., 6:00–8:00), the plug turns on if the battery is below a maximum threshold (e.g., 80%).
  • Turn Off Automatically: The plug switches off when the battery reaches 100%, preventing overcharging.
Why It’s Great:
This automation is incredibly customizable. Users can tweak thresholds and time windows to suit their needs. Plus, it’s reusable, making it easy to import and adjust for multiple devices.
How to Use It:
  1. Import the blueprint from GitHub or Gist in Home Assistant.
  2. Configure the required inputs, including the smart plug, battery sensor, thresholds, and schedule.
  3. Save the automation and reload if necessary.
User Feedback:
Several users have praised this automation for its simplicity and effectiveness. It’s a fantastic way to preserve battery life while ensuring your phone is always ready when you need it.
If you’re looking for a smarter way to manage your phone’s charging, I highly recommend giving this automation a try! Let me know if you have any questions or suggestions for improvement.
