Smart Stove Monitoring: A Hands-On Project
As the colder months approach, I’ve been thinking about ways to enhance my home’s comfort and safety. One area that’s always been a concern for my wife is ensuring that the stove is turned off before we leave the house. After some research and tinkering, I found a clever solution using my existing Aeotec HEM sensor. Here’s how I set it up and the results I’ve seen so far!
Project Background
My wife has always wanted a way to know if she left the stove on. While there are commercial solutions available, I wanted to see if I could repurpose hardware I already owned. The Aeotec HEM sensor, which I had lying around, seemed like a perfect fit. It’s designed to monitor energy usage, so why not use it to detect if the stove is on?
Setup Process
  1. Hardware Setup: I connected the Aeotec HEM sensor to my home’s power panel. It’s straightforward—just plug it in and let it monitor the power usage of the stove circuit.
  2. Configuration: I adjusted the sensor settings to detect the minimum power usage of the stove. After some testing, I found that the stove uses at least 100W when on, which the HEM sensor can reliably detect.
  3. Integration with Home Assistant: I used Home Assistant to create automations that send notifications when the stove is detected as being on for an extended period. This involved setting up a sensor to track the stove’s power usage and creating an automation rule to trigger alerts.
Challenges and Solutions
  • Initial Calibration: The sensor needed some fine-tuning to accurately detect the stove’s power usage. I ran several tests to ensure it didn’t false alarm or miss detections.
  • Integration Hiccups: Getting the sensor to communicate seamlessly with Home Assistant required some tweaking of the device type and settings. Thankfully, the community forums were a great resource for troubleshooting.
Results and Benefits
Since setting this up, we’ve had peace of mind knowing that the stove won’t be left on accidentally. The notifications are timely and clear, allowing us to address the situation immediately. It’s been a simple yet effective addition to our home automation setup.
Tips for Others
  • Start Small: If you’re new to home automation, start with a small project like this. It’s a great way to learn the basics without overwhelming yourself.
  • Leverage Existing Hardware: Look for ways to repurpose devices you already own. It can save you money and reduce waste.
  • Community Resources: Don’t hesitate to consult online forums and communities. They’re invaluable for troubleshooting and getting inspiration.
This project has been a fun and practical way to enhance our home’s safety. I’m excited to see how else I can integrate smart technology to make our lives easier. Happy tinkering everyone!
