Smart Switch Setup Tips and Tricks – Need Your Advice!
Hey everyone, I’m diving into the world of smart home automation and I’m absolutely loving it! However, I’ve hit a bit of a snag with my latest project and I could really use some guidance from the community.
I’m trying to set up a smart switch that automatically turns off after a few seconds, but I’m struggling to get it to work properly. Here’s what I have so far:
Switch PowerReleu1 “Power Releu 1” [ “Switchable” ] {mqtt=“>[broker:SmartHome/Power/Releu1:command:ON:Z3ON],>[broker:SmartHome/Power/Releu1:command:OFF:Z3OFF],<[broker:SmartHome/Power/Releu1/state:state:ON:Z3ON],<[broker:SmartHome/Power/Releu1/state:state:OFF:Z3OFF]”, autoupdate=“false”}
This setup works perfectly for manual switching, but when I try to add an expiration feature, it just doesn’t behave as expected. Here’s the modified version I’m testing:
Switch PowerReleu1 “Power Releu 1” [ “Switchable” ] {mqtt=“>[broker:SmartHome/Power/Releu1:command:*:default]”, expire=“2s,command=OFF”}
The goal here is for the switch to turn off automatically after 2 seconds if it’s not manually switched off. Unfortunately, it’s not working as intended, and I’m not sure where I’m going wrong. I’ve tried tweaking the expiration settings and even looked into different MQTT configurations, but nothing seems to stick.
I’d love to hear from anyone who has successfully implemented something similar or has a workaround for this issue. Maybe there’s a different approach or a setting I’m overlooking. Let me know if you’ve encountered this before and how you resolved it!
On a lighter note, I’ve been experimenting with other smart devices too, and it’s been a real learning curve. For instance, integrating my Apple TV with Home Assistant was a breeze, but I did run into an odd issue where it kept switching between idle and standby modes. After some research and tweaking, I managed to stabilize it, which was a huge relief!
If anyone has tips on troubleshooting or best practices for setting up smart switches, I’m all ears. It’s amazing how a little advice can make such a big difference. Thanks in advance for your insights and experiences!
Cheers,
