Smart Switch with IR Compatibility: A User's Journey
I’ve been on a quest to find the perfect smart switch that also supports IR compatibility. Let me share my journey and hopefully, it can help others who are in the same boat!
So, here’s the deal: I’ve been using a Leviton IR-compatible light switch for quite some time now. It’s worked well for me, but it’s not smart. I wanted to integrate it into my home automation setup without losing the IR functionality. After some research, I realized that finding a smart switch with IR compatibility wasn’t as straightforward as I hoped.
I started by exploring Zigbee and Tuya options since they’re widely supported in home automation ecosystems. I came across a few models that claimed to support IR, but many had hit-or-miss performance. Some worked reliably, while others were inconsistent. I even tried using an IR blaster, but its reliability was questionable. It was frustrating because I didn’t want to give up the convenience of controlling my lights with a universal remote.
After weeks of research and testing, I stumbled upon a solution that worked perfectly for me. I found a smart switch that not only supported IR but also integrated seamlessly with my home automation system. The best part? It allowed me to create scenes without relying on an external IR blaster. This was a game-changer for my setup!
Here’s a quick tip for anyone looking for a similar solution: Check reviews and forums for firsthand experiences. Sometimes, a model might look perfect on paper, but user feedback can reveal hidden issues. Also, consider the ecosystem compatibility. If you’re using Home Assistant, make sure the switch is well-supported within that environment.
In the end, my persistence paid off. I now have a reliable smart switch that meets all my needs. It’s been a great addition to my home automation setup, and I’m thrilled with the results. If you’re on a similar hunt, keep experimenting and don’t lose hope—there’s always a solution out there!
