I recently decided to upgrade my home automation setup by integrating some smart switches and a Bluetooth tracking system. Here’s my journey and some tips for anyone looking to do something similar!
Smart Switches for Storage Heaters
I’ve been looking for a way to remotely control my storage heaters. After some research, I found that a simple smart switch could do the trick. I went with a 13A-rated switch, which seems to handle the load perfectly. Now, I can turn my heaters on or off from anywhere using my phone. It’s been a game-changer for managing my home’s heating efficiently!
Bluetooth Tracking with ESPHome
I also wanted to set up a Bluetooth tracking system to keep tabs on my devices. I decided to use ESPHome for this project. The configuration was a bit tricky at first, but I managed to get it working after some trial and error. Here’s a quick overview of my setup:
yaml
Example ESPHome Configuration
esphome:
friendly_name: Bluetooth Tracker
api:
encryption:
key: REDACTED
wifi:
ssid: YourSSID
password: YourPassword
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
I paired this with Home Assistant’s built-in Bluetooth LE Tracker to monitor my devices. It’s been working smoothly, and I can now track my phone, keys, and other Bluetooth-enabled devices in real-time!
Tips for Success
- Start Small: Don’t dive into complex projects right away. Begin with something simple like a smart switch or a basic sensor.
- Read the Documentation: ESPHome and Home Assistant have excellent documentation. Spend some time going through them before diving into configurations.
- Test Regularly: After making changes, test your setup to ensure everything works as expected.
- Join Communities: Forums like this one are invaluable. Don’t hesitate to ask for help if you get stuck!
This project has been incredibly rewarding. It’s amazing how much you can do with a little tinkering and some smart devices. If anyone has questions or wants to share their own projects, feel free to drop a comment below! ![]()
