Hey everyone!
I wanted to share my journey with smart thermostat customization, as it’s been quite the learning experience. While I’ve had programmable thermostats for years, the challenge lies in adapting to daily schedule changes without constant manual adjustments. ![]()
Here’s the issue I faced: if I set the thermostat to lower the temperature during the day and raise it at 5 PM, it doesn’t account for days when we’re home and manually set the heat higher. This often leads to the thermostat overriding our manual settings, causing unnecessary discomfort. ![]()
After experimenting with various SmartApps and CoRE, I found a solution that works beautifully. Here’s how I tackled it:
SmartApps and CoRE Integration: I utilized apps from Rboy and CoRE to create a system that respects manual overrides. If the temperature is already higher than the programmed setting, the thermostat doesn’t adjust it. This prevents the frustrating scenario of the heat dropping when we’re already comfortable.
Mode-Based Control: Instead of relying solely on timed schedules, I implemented modes for different scenarios (e.g., “Away,” “Home,” “Evening”). This approach allows for more flexibility and reduces the need for constant adjustments.
Alexa Integration: Setting up modes through Alexa has been a game-changer. It’s seamless and ensures that the thermostat adapts to our daily routines without requiring constant manual input.
I’d love to hear how others have customized their thermostats or overcome similar challenges. Any tips or tricks you’ve discovered would be invaluable! ![]()
Let’s keep the conversation going and help each other create smarter, more comfortable homes! ![]()
