Hey everyone! I wanted to share my experience with integrating different sensors and my Ecobee thermostat to create a more efficient home heating system. I’ve been using Ecobee for a while now, along with some additional Wi-Fi thermometers and a smart sensor. My goal was to have my bedroom maintain a specific temperature while ignoring the main floor’s temperature, which can vary quite a bit.
Initially, I was frustrated because the Ecobee thermostat would only base its temperature adjustments on the main floor sensor. If the bedroom got too cold, the heating wouldn’t kick in because the main floor was still warm enough. After some research, I discovered that using Home Assistant automations could solve this issue. I set up a system where, during the night, the thermostat switches to using the bedroom sensor as the source for temperature adjustments.
I found that while Ecobee’s smart features are great, they didn’t quite meet my needs when combined with other devices. So, I decided to use the generic thermostat integration in Home Assistant, which gives me more control over how the Ecobee operates. This approach has been much more reliable and allows for precise temperature management without constant adjustments.
One tip I’d share is to experiment with different automation triggers in Home Assistant. I use time-based automations to switch the thermostat source at night and revert it back in the morning. It’s also been helpful to log the temperature data from both the main floor and the bedroom to fine-tune the settings.
This setup has made a significant difference in my comfort during the colder months. I no longer wake up to a chilly bedroom, and the heating system runs more efficiently since it’s not constantly adjusting based on the main floor’s temperature. It’s a small tweak, but it’s made a big impact!
If anyone has questions or wants to share their own smart thermostat setups, I’d love to hear about them!
