Hello everyone, I recently encountered an issue with my smart thermostat integration, and I wanted to share my experience and resolution in case others might find it helpful.
I integrated my smart thermostat with Smart Life, and initially, everything worked perfectly. However, after a while, the thermostat started showing an unusually high temperature of 225 degrees Celsius, which was clearly incorrect. The HVAC modes were functional, but the temperature readings were way off.
I checked the parameters and noticed some inconsistencies. The min_temp was set to 5, and the max_temp was an unusually high 1220, which seemed way beyond the typical range for a thermostat. The target_temp_step was 0.5, and the current_temperature was 235, which also didn’t make sense. I realized that these settings were likely causing the thermostat to malfunction.
I decided to modify these parameters to more realistic values. I set min_temp to 10, max_temp to 35, and adjusted target_temp_step to 1. I also corrected the current_temperature to match the actual room temperature. After making these changes, I restarted the integration, and the thermostat began functioning correctly again.
I also explored the possibility of interacting with the thermostat through the entity in Home Assistant. I found that adjusting the temperature via the entity worked seamlessly, and the thermostat responded as expected. This made me realize how important it is to verify and adjust integration parameters to ensure accurate functionality.
I hope this experience can help others who might be facing similar issues with their smart thermostats. If you’re encountering strange temperature readings or integration problems, double-check your settings and consider reaching out to the community for support. Happy automating!
