I wanted to share my recent experience setting up a smart thermostat and automated window shades system. After some trial and error, I finally got everything working seamlessly together. Here’s how I did it:The Goal I wanted to create a system where my smart thermostat would automatically adjust the temperature based on the time of day, while also controlling my window shades to optimize natural light and energy efficiency.The Setup - Smart Thermostat: I chose the Moes BHT-002-GCLZB thermostat for its Zigbee compatibility and sleek design. - Window Shades: I went with Somfy R28 wired motorized shades, paired with Qubino DC shutter modules for Z-Wave control. - Automation Hub: Everything is controlled through Home Assistant, using openHAB for rule creation.Challenges Faced 1. Motor Limits: Initially, the Somfy shades weren’t respecting their mechanical limits. I had to manually calibrate them by timing the motor movement. 2. Z-Wave Integration: The Qubino modules required careful configuration to ensure reliable communication with the Somfy motors. 3. Thermostat History: The Moes thermostat wasn’t showing temperature history out of the box, which was a minor inconvenience but easily resolved with a firmware update.The Solution After some research and tweaking, here’s what worked: - I set up a daily schedule in Home Assistant to adjust the thermostat temperature and control the shades. - During daylight hours, the shades partially open to let in natural light while maintaining privacy. - In the evening, the shades fully close to help retain heat. Tips for Others - Calibration is Key: Spend time fine-tuning motor limits and timing for shades. - Firmware Updates: Always check for the latest firmware for your devices. - Rule Testing: Use the openHAB paper UI to test rules incrementally before full deployment. Final Thoughts It was a bit of a learning curve, but seeing everything work together smoothly was worth it. My home now feels more comfortable and energy-efficient. If anyone has questions about similar setups, feel free to reach out!
