Smart things hub or just M100 hub
Do a need a smart things hub to connect Aqara sensors, I have a M100 aqara hub but doesn’t connect
@mreeder220 You don’t need a SmartThings hub to connect Aqara sensors. Aqara sensors must be paired with an Aqara Hub, and the M100 is a compatible Aqara Hub.
Since your M100 hub isn’t connecting the sensors, let’s try these troubleshooting steps first:
  1. Check if the M100 hub has the latest firmware installed. Outdated firmware might cause connection issues.
  2. Ensure the sensor is within a reasonable distance from the M100 hub—too far can weaken the signal.
  3. Verify the sensor is reset correctly (check if the LED indicator blinks as expected) and try re-pairing following the “Add Accessory” steps.
  4. Confirm there are no more than 32 child devices connected to the M100 hub, as exceeding this limit can prevent new pairings.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully. If the problem persists, feel free to share more details about the sensor model or specific error messages
