Smart Water Tank Monitoring with HC-SR04 Ultrasonic Sensor
I recently embarked on a project to monitor the water level in my home’s water tank using the HC-SR04 ultrasonic sensor, NodeMCU, and Home Assistant with MQTT integration. This setup has been a fascinating exploration of DIY smart home solutions, and I’d love to share my journey and insights with the community.Project Overview The goal was to create a system that not only measures the water level but also provides real-time updates and alerts. I decided to use the HC-SR04 sensor for its reliability and affordability. Pairing it with NodeMCU allowed me to leverage MQTT for seamless integration with Home Assistant. The sensor measures the water level in percentage and sends the data to Home Assistant, which then displays it on my dashboard.Challenges and Solutions One of the initial challenges was ensuring accurate readings. The HC-SR04 sensor can sometimes be sensitive to environmental factors like vibrations or nearby objects. I addressed this by securing the sensor firmly and positioning it away from potential obstructions. Additionally, I implemented a simple filtering algorithm in the NodeMCU code to smooth out any erratic readings.Another consideration was ensuring the system’s reliability. I set up a cron job to periodically check the sensor’s status and log the data. This has been invaluable for troubleshooting and ensuring consistent performance.Integration with Home Assistant Integrating the sensor with Home Assistant was straightforward thanks to MQTT. I created a custom card in Lovelace to display the water level, which now serves as a helpful indicator for monitoring water usage and tank refills. The ability to set custom thresholds for low water levels has added an extra layer of convenience.Lessons Learned This project reinforced the importance of thorough planning and testing. What started as a simple idea evolved into a comprehensive system that not only meets my needs but also serves as a learning tool. I’ve gained a deeper understanding of sensor integration, MQTT, and Home Assistant’s customization capabilities.Looking Ahead I’m already brainstorming ways to expand this project. Ideas include adding a solenoid valve for automated water level control or integrating a notification system to alert me when the tank needs refilling. The possibilities are endless, and I’m excited to continue refining this setup.If anyone has experience with similar projects or tips for improving this system, I’d love to hear your thoughts! Let’s collaborate and make our smart homes even smarter together. :rocket:
