Hi everyone,
I’ve been diving into the world of smart gardening and wanted to share my recent experience setting up an automated watering system for my greenhouse saplings. It’s been a learning curve, but I’m thrilled with how it’s coming together!
The Goal
I wanted to automate the watering process for my seedlings, which are grown in small trays where soil moisture sensors aren’t feasible. The challenge was to create a system that waters based on temperature trends rather than fixed schedules. Hotter weather means more frequent watering, and cooler weather means less.
The Setup
- Temperature Monitoring: I’m using an outdoor sensor to track temperature and integrate it with OpenWeatherMap for more accurate data.
- Misting System: I’ve set up misting cycles to keep foliage from drying out, which works well for humidity control.
- Watering Automation: I created a script that sums daily temperatures and triggers watering cycles based on accumulated heat.
Challenges and Solutions
- Recording Temperature Data: I struggled with how to log the maximum temperature each day at 16:00. After some research, I found that using a combination of sensors and time-based triggers in Home Assistant worked perfectly.
- Summing Temperatures: Calculating the sum of temperatures over several days was tricky, but I discovered that using a combination of sensors and custom scripts allowed me to track this effectively.
- Watering Cycle Automation: Resetting counters after each watering cycle was essential to avoid overwatering. I implemented a system that resets all counters once a watering cycle completes.
Lessons Learned
- Custom Scripts: Writing custom scripts was a steep learning curve, but it paid off in terms of flexibility and precision.
- Integration: Integrating multiple sensors and data sources was key to creating a reliable system.
- Automation: Automating the watering process not only saves time but also ensures consistent care for the plants.
Tips for Others
- Start Small: Begin with a small setup and gradually scale up as you gain confidence.
- Experiment: Don’t be afraid to tweak your system based on real-world data and observations.
- Community Support: Don’t hesitate to reach out to forums like this one for advice and troubleshooting. The community here is incredibly helpful!
I’m really excited about how this system is improving my gardening process. If anyone has questions or suggestions, I’d love to hear from you!
Cheers,
