Hey everyone, I wanted to share my recent success with integrating my Broadlink RM4C Mini into Home Assistant using SmartIR. After some initial confusion, I managed to set it up perfectly for controlling my window AC and portable heater. Here’s how I did it and some tips for those who might be struggling:
1. Understanding SmartIR: SmartIR is a fantastic tool for controlling IR devices, but it can be a bit overwhelming at first. I started by manually controlling my devices through the HA dashboard, which worked smoothly. However, I wanted to automate things further, especially for temperature management.
2. Setting Up Climate Components: The challenge was getting SmartIR to recognize my devices as climate components. Since my devices aren’t “known” in the database, I had to create custom JSON templates. This was a bit tricky, but I found some helpful guides online that walked me through the process step by step.
3. Automation Magic: Once the devices were recognized, I set up an automation where the heater turns on if the room gets too cold and the AC kicks in if it gets too warm. This has been a game-changer for maintaining a comfortable temperature without manual intervention.
4. Tips for Others:
- Start Simple: Begin with manual controls to ensure your IR blaster is working correctly before diving into automations.
- Custom Templates: Don’t shy away from creating custom JSON templates. There are plenty of resources and communities willing to help.
- Temperature Management: If you’re only needing on/off functionality, focus on that first before adding temperature controls.
5. Community Support: I couldn’t have done this without the support from forums like this. If you’re stuck, don’t hesitate to ask. Someone out there has likely faced the same challenge and is happy to help.
I hope this helps anyone looking to integrate their IR devices with SmartIR. Let me know if you have any questions or tips to share! ![]()
