Smartphone as Presence Sensor: Overcoming VPN Challenges
Hey everyone, I wanted to share my recent experience with setting up smartphones as presence sensors in my smart home setup. It’s been quite the journey, and I thought I’d document my findings in case others are dealing with similar issues.
So, here’s the setup: I’ve got a few kids, and I wanted to use their smartphones as presence sensors to automate certain tasks around the house—like turning on lights when they’re nearby or adjusting the thermostat based on who’s home. Sounds straightforward, right? Well, it turned out to be a bit more complex than I anticipated.
The main challenge I faced was related to our family’s use of Qustodio for child monitoring. It seems that Qustodio’s monitoring features were interfering with the ability to connect the phones as presence sensors. Initially, I thought it might be a simple matter of tweaking some settings, but after some research and experimentation, it became clear that Qustodio was blocking the necessary connections entirely.
To solve this, I did a bit of digging and found that temporarily disabling Qustodio allowed the phones to connect as presence sensors without any issues. Of course, disabling monitoring software isn’t ideal, especially when it comes to kids, but it was a helpful test to confirm that the software was indeed the culprit.
After some back-and-forth with Qustodio’s support team and exploring alternative solutions, I discovered that there might not be a perfect workaround at this time. However, I did manage to find a compromise by setting up specific times when monitoring was less critical and enabling presence sensing during those periods. It’s not a perfect solution, but it’s better than nothing.
For anyone else dealing with similar issues, here are a few tips:
  • Check for Conflicting Software: If you’re using any parental control or monitoring software, it might be worth checking if it’s interfering with your smart home setup.
  • Test with Monitoring Disabled: Temporarily disabling monitoring software can help identify if it’s the source of the problem.
  • Communicate with Support: Reaching out to the support teams of your monitoring software might yield some insights or potential fixes.
  • Consider Alternative Solutions: If conflicts are too persistent, exploring alternative monitoring or presence sensing solutions might be necessary.
It’s been a bit of a rollercoaster, but I’m glad I was able to find at least a partial solution. I’d love to hear if anyone else has encountered similar issues or has found more effective workarounds!
Cheers,
