Hello everyone, I’ve been exploring the SmartThings ecosystem and wanted to share some insights and tips regarding the integration with Samsung Smart TVs. I’ve had a lot of success and a few bumps along the way, so I thought it would be helpful to compile my experiences here.
First, I’d like to address the question many of us have: Can SmartThings control a Samsung Smart TV? The answer is yes, but it might require a bit of setup. I’ve successfully integrated my Samsung JS9000 TV with SmartThings, and it’s been a fantastic addition to my smart home setup. The ability to control the TV through routines and scenes has really enhanced my experience.
One thing I discovered is that the integration works seamlessly if you use the SmartThings app alongside the Samsung SmartThings app. This dual setup allows for a more comprehensive control over your devices. I was initially concerned about compatibility, but everything has worked out smoothly so far.
For those looking to add multiple Samsung TVs to their SmartThings setup, I recommend ensuring that each TV is properly registered in the SmartThings app. This involves going through the device discovery process and making sure that each TV is recognized as a separate entity. I found that doing this step-by-step for each TV helped prevent any confusion or overlap.
Another tip I’d like to share is about customizing scenes and routines. Once your TV is integrated, you can create scenes that not only control the TV but also adjust other connected devices like your Hue lights or Sonos speakers. For example, I created a ‘Watch Movie’ scene that dims the lights, turns off the Hue bulbs, and switches the TV to my preferred input. It’s all about creating a seamless experience!
I also wanted to touch on the Extend app mentioned in some forums. While it’s a powerful tool for advanced users, I found that the native SmartThings integration was sufficient for my needs. However, if you’re looking to push the boundaries of what’s possible, Extend is definitely worth exploring.
One challenge I faced was ensuring that the TV’s current state (on/off, volume, etc.) was accurately reflected in the SmartThings dashboard. After some research, I learned that this is handled automatically once the integration is properly set up. It’s all about letting the system do the work in the background.
Lastly, I’d like to thank the community for all the helpful resources and forums. It’s amazing how much support and knowledge are available here. If anyone has specific questions or runs into issues, please don’t hesitate to ask. We’re all here to help each other out!
Happy integrating, and here’s to smarter homes!
Best regards,
