SmartThings and Wemo Integration Success Story
After months of trial and error, I finally managed to integrate my SmartThings setup with Wemo light switches! The journey wasn’t smooth, but the result is seamless control across both ecosystems. Here’s how I did it:
  1. Apps Used: I relied on SmartThings, Tasker, Sharptools, and WemoManager. These apps worked together to bridge the gap between SmartThings and Wemo.
  2. Setup Steps:
    • Removed Wemo switches from SmartThings.
    • Created virtual On/Off buttons in SmartThings IDE.
    • Authorized Sharptools to interact with SmartThings devices.
    • Configured WemoManager for precise control.
    • Set up Tasker to handle intents and automate responses.
  3. Outcome: Now, I have 9 Wemo switches flawlessly integrated with SmartThings. The only minor hiccup is a slight lag in 3-way switch setups, but it’s negligible.
  4. Tips: If you’re attempting this, patience is key. Test each switch individually before moving on to more complex setups.
This achievement has significantly enhanced my home automation setup. I’m thrilled to share this solution and hope it helps others too!
