SmartThings Automation Success Story: Temperature-Based Outlet Control
I recently embarked on a project to automate my garage using SmartThings, and I’m thrilled to share my success story. My goal was to create an automation that turns on an Amazon smart outlet if the temperature rises above a certain threshold using the SmartThings Multipurpose Sensor. While the process had its challenges, the outcome was well worth the effort.
Initially, I encountered a hurdle because the Alexa app didn’t recognize the SmartThings Multipurpose Sensor as a thermometer—it only allowed automations based on door open/close status. This was a bit frustrating, but I didn’t give up. After some research and experimentation, I discovered that integrating the sensor with SmartThings routines was the key. By setting up a custom routine in the SmartThings app, I was able to trigger the outlet based on temperature readings from the sensor. This setup now ensures that my garage stays at a comfortable temperature, especially during those chilly winter nights.
Another aspect of my project involved setting up mqtt on my openHAB system. I’ve been running openHAB for about six months and decided to dive into mqtt to enhance my home automation capabilities. With the help of the mqtt2 binding and mqtt generic thing binding, I successfully configured the embedded broker in openHAB. Using mqttfx on a separate laptop to monitor the setup was incredibly helpful. I learned that creating channels in the generic mqtt thing and linking them to items was the way to go. This setup now allows me to send mqtt messages from my phone’s Tasker app to openHAB when connected locally, adding a new layer of control to my smart home.
I also wanted to share my experience with the Sonoff switches. After successfully flashing them with custom firmware, I integrated them into my SmartThings ecosystem. The process involved using the NodeMCU flasher and carefully following the flashing instructions. It was a bit nerve-wracking, but seeing the switches come online and work seamlessly with SmartThings was incredibly satisfying. The ability to control them via the SmartThings app and set up routines has added a lot of convenience to my daily life.
Lastly, I’ve been exploring ways to use the Wyze smart plug to control a heat lamp for our cat. While Wyze doesn’t offer built-in rules for temperature-based automation, I found a workaround by integrating it with a Wyze Sense Climate Sensor. This setup allows the plug to turn on when the temperature drops below a certain threshold and off once it rises, ensuring our feline friend stays warm in the garage.
Overall, this project has been a fantastic learning experience. It’s amazing how combining different devices and platforms can create a smart home that truly meets your needs. I’m excited to continue exploring and enhancing my automation setup!
