SmartThings Motion Sensor Not Detecting Motion Only Temperature
Since about August 23rd, 2016, I’ve noticed that two out of my ten SmartThings motion sensors are only reporting temperature and not detecting any motion. I’ve tried removing and re-adding them, as well as changing the batteries, but the issue persists. Interestingly, one sensor is in my garage and the other in my shed, both in environments with higher temperatures, but still within the max spec. I’ve also tested other sensors in the same locations, and they work fine. I’m wondering if there’s a firmware update or a setting I might have missed. Has anyone else encountered this issue? Any suggestions would be greatly appreciated!
