SmartThings Multi Sensor Garage Door Integration Tips
Hey everyone, I’ve been tinkering with my SmartThings Multi Sensor to monitor my garage door. Initially, I was using the magnetic sensor, which worked perfectly for detecting open/closed states. However, I wanted to switch to using the tilt sensor for better integration within the SmartThings ecosystem.
After some trial and error, here’s what I learned: When categorizing the sensor as a ‘garage door,’ it defaults to using the tilt sensor. However, I noticed that notifications for open/closed states stopped working. I realized that the tilt sensor alone wasn’t triggering the notifications I needed.
To resolve this, I reverted to the magnetic sensor setup, which reliably sends notifications to my Evolve LFM-20 when the door is left open too long. While I couldn’t get the tilt sensor notifications working as intended, the magnetic sensor setup proved to be the most reliable solution for my needs.
If anyone has successfully configured the tilt sensor for notifications, I’d love to hear your setup details! It’s always great to learn from the community. Thanks for your insights!
