Earlier this week, I experienced a situation that reminded me just how valuable my SmartThings setup truly is. It all started when I was working from home and suddenly noticed my main water valve had shut off automatically. At first, I was puzzled—why would the valve turn off without any warning? Little did I know, this was a lifesaver in disguise.
As it turns out, my SmartThings leak sensor detected water on the floor in my laundry room. The sensor, a simple yet effective $25 device, picked up the moisture and immediately triggered the system to take action. Not only did it shut off the main water valve to prevent further damage, but it also turned off the clothes washer, which was plugged into a Zigbee outlet. This quick response likely saved me from a costly water damage situation.
The culprit turned out to be a failing drain pump in my laundry room. The pump had developed broken blades, a cracked housing, and a failed seal, all of which contributed to the leak. While I was aware the pump was aging, I hadn’t expected it to fail so catastrophically. Fortunately, the SmartThings system caught the issue before it could escalate into a full-blown disaster.
I’m incredibly grateful for this early warning system. Dealing with a water leak can be stressful and expensive, but thanks to my SmartThings setup, I only had to pause laundry for a day or two while I waited for a replacement pump to arrive. This experience has reinforced my belief in the importance of having a reliable home automation system in place.
If you’re considering adding leak detection to your SmartThings setup, I highly recommend investing in a quality leak sensor. It’s a small price to pay for the peace of mind it provides. After all, preventing even one water leak can easily justify the cost of the entire system.
Thank you, SmartThings, for being my unsung hero this week! ![]()
