I’ve recently added two Smartthings Water Leak Sensors to my home security setup, and I wanted to share my experience and some troubleshooting tips in case others are encountering similar issues. First, the good news: the sensors paired effortlessly with my hub, and the initial setup was straightforward. The device detects moisture almost instantly, as the LED turns red when wet, which is a great visual confirmation. However, I encountered a peculiar issue where the moisture status wasn’t being communicated to the Smartthings platform. Instead, the app only showed the sensor as ‘dry’ and didn’t display any moisture events online. The device itself seemed to be working fine, as it detected moisture and even logged events locally, but these weren’t syncing with the hub. After some research, I realized this might be a firmware or configuration issue. I reached out to the community and found that others hadn’t reported the same problem, which made me think it might be specific to my setup. I decided to try resetting the sensors by removing and re-adding them to the hub. To my relief, this resolved the issue, and now the moisture events are syncing perfectly. It’s always a bit nerve-wracking when devices don’t work as expected, but the Smartthings community and their support resources are invaluable. If anyone else is experiencing similar issues, I’d recommend checking the firmware version, ensuring the sensors are within range of the hub, and trying a factory reset as a first step. Happy smart home tinkering! ![]()
