Smoke detector losing connection
I have 4 smoke alarms and an M100 hub. I’ve had them for about a month and have experienced them going offline; they only come back online when I press the physical button. This is very problematic, as they are supposed to monitor my home — among other things — while I am away.
Has anyone else experienced something similar and have an explanation?
They are not located far from each other or from the hub.
Hey there and welcome to the forum .what is the distance between the smoke detectors and the M100?because I have 2 one on my living room and one on my bedroom witch is a bit far from the M3 hub but I have my LED strip from Aqara witch make an zigbee router.so if they are to far and walls in between you need to add some light bulbs or smart plugs in between the hub and the M100 but only were those smoke detections are not near to the M100.this is why your smoke detectors goes offline because they loose connection with the hub.and my be could be also some interference on the 2.4Ghz band witch zigbee is using to communicate.
The distance is between 5 and 10 meters. Not much wall, mainly doorways.
Still even if you have an wall and 5m could lead to that issue as zigbee network is like the WiFi on 2.4Ghz and that could lead on interruptions or offline devices if there are some interference between that is why yo make you zigbee network better and stable you need to add at least one smart plug in between or light bulb and after that you should reset again your smoke detectors and repair it back so they can connect via the zigbee device you added in between.but could also be an issue on your WiFi 2.4Ghz band as if the hub reboots or disconnect and reconnect also could set those smoke detectors offline and this devices being batterie powers take some time to reconnect by themselves.
For a safety device, it’s the worst problem, because you only see it when you press the button. Like coccolino said, a Zigbee router on power between the hub and the detectors is the first thing I would try, even at 5 to 10 m. Doorways look open, but the signal still bounces on walls and appliances.
While the ticket is open, ask support if they see the detectors reconnecting in their logs, and send them the hub firmware and the detector firmware. And set a notification when a detector goes offline, so you don’t find out by luck.
