Solar Thermal Pool Heating System Visualization and Control
As a homeowner with a passion for sustainable living, I’ve always been fascinated by integrating smart technology into my home. My latest project has been configuring a solar thermal pool heating system, and I’m thrilled to share my journey with the community. My setup combines solar thermal collectors, photovoltaic panels, and a pool heat exchanger. The system is monitored and controlled using openHAB, with sensors and relays managed through MySensors nodes. The goal is to optimize energy usage, ensuring the pool pump runs efficiently during peak solar production while maintaining pool temperature. One of the biggest challenges was refining the widget interface for the openHAB dashboard. I wanted a visualization that clearly shows the flow of solar thermal water between the pool and the house heating system, as well as real-time temperature data. After several iterations, I managed to create a dynamic interface that switches between pool and boiler modes, providing a clear overview of system status. Here are a few tips I’ve learned along the way: - Optimize Pump Scheduling: Running the pump only when there’s excess solar energy significantly reduces grid dependency. - Automate Valve Switching: Setting thresholds for temperature differences ensures seamless switching between pool and house heating modes. - Regular Maintenance: Monitoring sensor accuracy and checking relay functionality are crucial for reliable operation. I’m eager to hear your thoughts and suggestions for further optimization. Whether it’s improving the widget code or enhancing system efficiency, your insights are invaluable! Thanks for reading, and I look forward to your feedback. Happy tinkering! :rocket:
