Solved! Connection Issue with Arlo Pro 3 and VMB-3000 Base
Hi everyone,
I wanted to share my experience and solution to a connection issue I faced with my Arlo Pro 3 camera and the VMB-3000 base. Hopefully, this helps someone else who might be going through the same frustration.
The Problem
After setting up my Arlo Pro 3 camera, I noticed that it wasn’t connecting properly to the VMB-3000 base. I tried several troubleshooting steps:
- Resetting the camera: I followed the standard reset procedure, but it didn’t resolve the issue.
- Re-syncing the camera: I attempted to re-sync the camera with the base, but it kept disconnecting.
- Unplugging and re-plugging: I tried unplugging both the camera and the base, but it didn’t make a difference.
The camera wouldn’t even show up in the Arlo app or on the Arlo website, which was really frustrating.
The Solution
After some research, I came across a suggestion to reset the VMB-3000 base unit. I was hesitant because I had another working camera connected to it. However, I decided to give it a try, and here’s what I did:
- Power off the VMB-3000: I unplugged the base unit from the power source.
- Wait for 10 seconds: I gave it a short break to ensure it fully powered down.
- Power it back on: I plugged the base unit back in and waited for it to restart.
- Re-sync the camera: Once the base was back online, I tried re-syncing the Arlo Pro 3 camera again.
This time, it worked perfectly! The camera connected without any issues, and it’s been running smoothly ever since.
Key Takeaways
- Resetting the base unit can sometimes resolve connection issues, even if other troubleshooting steps don’t work.
- Don’t be afraid to reset the base, even if you have other working cameras. It shouldn’t affect them, but it’s always a good idea to have a backup plan just in case.
I hope this helps anyone else struggling with a similar issue. It’s always a relief to finally get everything working as it should!
Best regards,
