SOLVED: Persistent Security Update Notification on Amazon Fire TV Remote
I’ve been dealing with this persistent security update message on my Amazon Fire TV remote, and it’s been quite the nuisance! Every time I turned it on, it would display the message: ‘Update in Progress Amazon Fire TV Remote is installing important security and software updates. This may take up to 1 to 2 minutes. - Do not press any buttons on the it is pretty annoying.’ I tried replacing the batteries, rebooting the device, and even letting it sit for a while, but the message kept showing up until I pressed the home button. Finally, I figured out a solution that works!
First, I made sure the remote’s batteries were fresh. Even though I had just replaced them, it was worth double-checking. Next, I ensured that the Fire TV device itself was fully updated. Sometimes, the remote’s firmware relies on the Fire TV being up to date. I went into the Fire TV settings, checked for updates, and installed any that were available.
After that, I performed a full shutdown of both the Fire TV and the remote. I held down the power button on the Fire TV until it turned off completely, then did the same for the remote. Once both devices were off, I waited about 30 seconds before turning them back on. This gave the devices a clean slate to start fresh.
To prevent this issue from recurring, I now make sure to update both the Fire TV and the remote regularly. I also avoid pressing any buttons on the remote while it’s updating, as this can sometimes interfere with the process.
If anyone else is struggling with this issue, I hope this solution helps! Let me know if you have any other questions or if there’s anything else I can assist with.
