Solving a Feline Dilemma with Smart Home Automation
I recently encountered a delightful yet slightly concerning situation with my cat, who has a knack for sneaking into our walk-in closet and hiding. One day, we accidentally locked her in for a couple of hours, which resulted in a bit of carpet damage. This incident prompted me to think about how I could prevent such occurrences in the future.
I decided to set up a simple automation using a motion sensor and a door sensor. The idea was to send a notification if the door was closed and motion was detected inside the closet. To add a fun touch, I also included a smart bulb that would turn on when the automation triggered.
However, I quickly realized that every time we closed the door, the automation would trigger because the motion sensor detected our movement as we exited. This was a bit of a nuisance, so I started looking for a way to delay the trigger.
After some research, I found that I could configure the automation to wait for four minutes after the door closes. This delay allows the motion sensor to reset, ensuring that the automation only triggers if there’s unexpected movement inside the closet.
This setup has worked beautifully! It not only helps keep our cat safe but also adds a layer of convenience to our daily routine. If you’re looking to implement a similar solution, I recommend experimenting with automation delays and testing your sensors thoroughly.
It’s amazing how smart home technology can turn a potential problem into a manageable and even entertaining solution. If anyone has further tips or alternative approaches, I’d love to hear them!
