I’ve been a fan of using Amazon Dash Buttons as a budget-friendly way to add hardware buttons to my smart home setup. They’ve been working pretty reliably for the most part, but recently I’ve noticed that some of them aren’t being recognized by my openHAB system. This has been a bit puzzling, so I thought I’d share my experience and see if anyone else has encountered similar issues or has some insights.
Let me start by explaining my setup. I have several Dash Buttons configured in my openHABianPi environment, running openHAB 2.3.0-1 with the amazondashbutton-binding version 2.3.0. Most of them work without any problems, but one specific button, the ‘Ariel’ button, has suddenly stopped being detected. This is frustrating because I know it was working fine in the past, especially with older versions of openHAB.
Here’s what I’ve tried so far:
- Confirmed ARP Requests: Using Wireshark, I’ve verified that the button is indeed sending ARP requests when pressed. This means the button itself isn’t the issue—it’s something on the openHAB side.
- Checked Logs: I’ve reviewed both the info and debug logs in openHAB, but there’s no entry indicating that the button press was detected. This suggests that the binding isn’t picking up the signal.
- MAC Address Configuration: I’ve double-checked the MAC addresses in my configuration to ensure there are no typos or mismatches.
- Network Interface: All buttons are set to use the same network interface (
eth0), so that shouldn’t be the problem.
One thing I’m considering is whether there might be a conflict with other devices on the network, but I haven’t added any new devices recently. Another possibility is that there’s an issue with the specific MAC address of the problematic button. I’ve heard that some Dash Buttons might have quirks depending on where they were purchased, but I’m not sure if that’s relevant here.
I’d love to hear from anyone who has experienced similar issues or has managed to resolve them. Have you ever had a Dash Button stop working with openHAB? What steps did you take to fix it? Any advice or suggestions would be greatly appreciated!
In the meantime, I’ll keep experimenting with different configurations and keep an eye on the logs to see if I can pinpoint the issue. Fingers crossed, it’s just a minor tweak away from being resolved!
