I recently encountered an interesting challenge with my home automation setup that I thought might be worth sharing. I have an automation in place that adjusts the temperature in my living room based on the average room temperature. The automation works as follows:
yaml
- alias: Temperature Adjustment
trigger:- platform: numeric_state
entity_id: sensor.average_temp
above: 19.8
action: - service: switch.turn_on
entity_id: switch.sonoff_1000df7ffb_3 - delay: ‘00:00:05’
- service: switch.turn_off
The goal here was to have the switch turn on when the temperature exceeds 19.8°C, stay on for 5 seconds, and then turn off. However, I noticed that the delay wasn’t consistent, especially when the temperature fluctuated throughout the day. This inconsistency led me to explore how I could dynamically adjust the delay based on the current temperature.
After some research and experimentation, I found that using a combination of templates and conditional logic within the automation allowed me to set different delays depending on the temperature range. For example, if the temperature is between 19°C and 20°C, the delay is set to 4 seconds, while between 18°C and 19°C, it’s set to 3 seconds. This approach not only made the automation more responsive but also tailored the behavior to the specific conditions of my home.
I’d love to hear if others have tackled similar issues or have suggestions for improving this setup further. It’s always fascinating to see how small adjustments can lead to significant improvements in smart home functionality!
