Solving Automation Triggers with Conditions
Hey everyone! I’ve been diving into setting up some smart home automations and wanted to share my journey in case it helps others. I was trying to create an automation that turns off the lights in my gaming room after 10 minutes of no motion, but I kept running into issues where the lights turned off immediately when the door closed, regardless of motion. It was super frustrating because I thought I had the conditions set correctly.
After some research and trial and error, I figured out that the timing and conditions needed a bit more finesse. I realized that the automation wasn’t accounting for the exact moment the door closed and the lack of motion in the meantime. I ended up adjusting the trigger to ensure it only activates if both the door is closed and there’s no motion detected for the specified time.
Here’s a quick tip for anyone else struggling with similar issues: make sure your conditions are set with a slight delay to allow for any potential sensor lags. It’s also been super helpful to break down the automation into smaller parts to test each condition individually before combining them.
I’d love to hear if anyone has tips or tricks for refining automation conditions or has faced similar challenges! :blush:
