I recently faced a frustrating issue with my Wyze cameras after upgrading my router. The cameras wouldn’t connect through the app, despite showing up on the Wi-Fi client list. After some research and troubleshooting, I found a solution that might help others in a similar predicament.
First, I realized that the problem was specific to the Doorbell Pro. While other cameras worked seamlessly, this one stubbornly refused to connect. I tried resetting it multiple times, but success was fleeting. The camera would briefly connect and send notifications, but the connection never lasted.
After reaching out to the community, I discovered that others had similar issues. The consensus was to ensure the camera was on the correct Wi-Fi band. Wyze cameras, like many others, prefer the 2.4 GHz band for stability. Despite the camera detecting both 2.4 GHz and 5 GHz networks during setup, it would only reliably connect to the 2.4 GHz network.
Here’s what I did to resolve the issue:
- Check the Wi-Fi Band: Ensure your camera is set to connect to the 2.4 GHz network. This can usually be done during the initial setup or through the camera’s settings in the app.
- Reset and Reconnect: Completely reset the camera and go through the setup process again, explicitly selecting the 2.4 GHz network.
- Network Settings: Temporarily disable any band steering features on your router that might force devices onto the 5 GHz band.
- Firmware Update: Check for any available firmware updates for your camera and router, as these can improve compatibility.
By following these steps, my Doorbell Pro now maintains a stable connection. It’s a relief to have consistent performance, especially since the camera is crucial for monitoring my home.
If you’re struggling with similar issues, I hope this guide helps. Remember, sometimes the solution is as simple as ensuring your devices are on the right network band. Happy troubleshooting!
