Solving Camera Delay in RTSPtoWebRTC Integration
Hey everyone, I’ve been using the RTSPtoWebRTC integration in Home Assistant for a while now, and I’ve noticed something a bit frustrating. While the camera feeds load up perfectly on my computer, there’s a significant delay when I try to view them on the Home Assistant Android app. Sometimes it can take up to 30 seconds for the image to appear, which is pretty inconvenient, especially when I’m trying to check something quickly.
I’ve come across a few discussions where others have mentioned similar issues, so I know I’m not alone in this. After doing some research and experimenting with different settings, I found that adjusting the camera’s streaming settings and ensuring that the Home Assistant instance is optimized for low-latency streaming can make a big difference. I also discovered that using a more reliable internet connection helps reduce the delay.
If anyone else is experiencing this issue, I’d love to hear what solutions you’ve found. Maybe there’s a tweak or a setting I haven’t considered yet. Let’s keep the conversation going and help each other out!
Cheers,
