I’ve recently encountered some challenges while trying to add new devices to my Vera2 system, and I wanted to share my experiences and solutions with the community. Hopefully, this can help others who might be facing similar issues.
First, a bit about my setup: I have both a Vera1 and Vera2 controller, with Vera2 as the primary. I’ve been using Vera1 for years, but now that Vera2 is the main controller, I’ve had to rely solely on it for adding new devices. Unfortunately, I’ve run into some roadblocks when trying to include new Z-Wave devices.
One of the devices I’ve been trying to add is a GE Dimmer Switch. It’s a brand-new unit, so it should be compatible with my Vera2. I’ve followed the standard pairing process: putting Vera2 into inclusion mode, pressing the button on the dimmer to send its signal, and waiting for Vera2 to recognize it. But time after time, I’ve gotten the same result: the Vera2’s Z-Wave light blinks once, but doesn’t confirm that the device has been added. After a minute or so, Vera2 exits inclusion mode, and the device isn’t listed in my network.
I’ve tried this with three different devices now: the GE Dimmer, an INSTEON Plug-In Switch that was previously part of my network, and a GE Outdoor Module. None of them have been successfully added. This is frustrating, especially since I’ve had no issues adding devices in the past with Vera1.
After some research, I came across a few potential solutions that others have tried:
Resetting the Vera2: Sometimes, a simple reboot can clear up connectivity issues. I’ve tried this a couple of times, but it hasn’t made a difference in my case.
Checking the Z-Wave Network Health: Vera2 has a built-in tool to check the health of your Z-Wave network. Running this diagnostic hasn’t shown any issues, so it doesn’t seem to be a problem with the existing network.
Using Vera’s Advanced Inclusion Mode: I’ve heard that Vera allows for advanced inclusion modes where you can manually input device IDs or enter a programming mode. I’m not entirely sure how to do this, but I’m planning to look into it more.
Updating Vera2’s Firmware: I’ve made sure that Vera2 is running the latest firmware version. Updates can sometimes resolve bugs that cause pairing issues.
Testing with a Different Power Source: I’ve tried powering Vera2 directly from the wall instead of using the battery pack, but this hasn’t helped either.
Checking for Interference: I’ve moved Vera2 closer to the devices I’m trying to add and ensured there are no obstructions or sources of interference in the area.
At this point, I’m leaning towards the possibility that Vera2 might have a hardware issue, but I’m hesitant to jump to that conclusion without trying more troubleshooting steps. I’ve also reached out to the Vera support team, but I’m hoping the community might have some additional insights or tips that I can try.
In the meantime, I’ve been using Vera1 to manage my existing devices, but I’d really like to get Vera2 fully operational again. It’s a powerful controller, and I’d hate to have to rely on Vera1 indefinitely.
If anyone has experienced similar issues or has successfully resolved them, I’d love to hear about your experiences! Maybe together we can figure out a solution.
