I recently encountered an issue with my Govee Sync Center, which was quite frustrating. My lamp had stopped working, and I wanted to delete it to create a new DreamView setup. However, the device couldn’t be deleted because it was set as a Sync Center, and the system required me to delete DreamView 2 first. Unfortunately, DreamView 2 couldn’t be deleted either since it couldn’t connect to the lamp. This was really perplexing!
After some research and trial and error, I found a workaround. I realized that the Sync Center needs to be reset or reconfigured properly. By following the steps to reset the device and then carefully setting up the new DreamView, I was able to resolve the issue. It was a bit time-consuming, but persistence paid off!
I also noticed that Govee limits the number of lamps you can add to a DreamView, which can be a challenge if you have many lamps, like I do. To work around this, I started creating multiple DreamViews and organizing them by zones. This way, I can manage my lamps more effectively without hitting the limit.
If anyone else is struggling with Govee devices, I recommend checking the official forums or reaching out to their support team. They have some great resources and community solutions that can help you troubleshoot and optimize your setup. Happy syncing everyone!
