Solving IP Camera MP4 Playback Issues: A Step-by-Step Guide
Hey everyone, I wanted to share my recent experience with getting video playback working on my IP camera setup. I’ve been using an Android IP camera to record videos, but I was running into issues where the MP4 files wouldn’t play back—neither in Home Assistant nor on Windows Media Player. It was pretty frustrating, but after some digging, I figured out a solution I wanted to share.
First, I realized the issue was likely related to the video encoding settings on the camera itself. I started by checking the camera’s app settings to see if there were any codec or resolution options I could tweak. After some trial and error, I found that switching the codec from H.265 to H.264 made a huge difference. H.264 is more widely supported, so it wasn’t surprising that this fixed the playback issue.
For those of you using Home Assistant, I also adjusted the media player settings within the Home Assistant UI to ensure it was set to the correct codec. This involved navigating to the camera’s entity settings and verifying that the video stream was configured properly. I also found that clearing the cache and re-syncing the camera within HA helped ensure everything was up to date.
Another thing I discovered was that sometimes the file paths or naming conventions could cause issues. I made sure all my recorded videos were being saved to a consistent location and that the filenames didn’t contain any special characters that might trip up the playback software.
If you’re still having trouble, I recommend checking the logs in Home Assistant for any errors related to media playback. This can often give you a clue about what’s going wrong. You can access the logs by going to the Supervisor tab in the HA UI and then selecting the relevant logs.
All in all, it was a bit of a learning curve, but now my videos are playing back perfectly! I hope this helps anyone else out there struggling with similar issues. Happy automating!
