I’ve recently encountered an interesting challenge with my Philips LED lights and the HM-LC-Dim1T-FM dimmer. While the setup works perfectly in terms of functionality, I noticed some flickering at certain dimming levels. This was particularly noticeable when the lights were left on for extended periods, which made me wonder if there was a way to fine-tune the system to eliminate this issue.
After some research and experimentation, I discovered that adjusting the dimmer’s ramp-up and ramp-down times made a significant difference. By tweaking these settings, I was able to reduce the flickering to almost imperceptible levels. Additionally, playing around with the over-temperature detection parameters helped ensure more stable operation overall.
Here’s a quick tip for anyone else experiencing similar issues: Start by adjusting the ramp times slowly and observe how the lights respond. It’s also worth checking if your LED bulbs are fully compatible with the dimmer’s settings range. A little trial and error can go a long way in achieving that perfect balance between functionality and performance!
Would love to hear if others have encountered and overcome similar challenges. Let’s keep the knowledge flowing! ![]()
