Motion sensors are a cornerstone of any smart home setup, but false alerts can be a real nuisance. I recently installed a Wyze motion sensor above my front door, carefully positioning it to avoid alerts from passing cars. The PIR sensor worked wonders, eliminating false triggers from nearby vegetation. However, this morning I noticed a persistent issue—alerts were firing even when there was no one outside. The culprit? Direct sunlight hitting the sensor during the early hours of the morning.
I decided to experiment with the sensor’s placement, moving it slightly to the right and adjusting its angle to avoid direct sunlight. The results were almost immediate—false alerts decreased significantly. This experience taught me the importance of considering environmental factors when setting up smart home devices.
If you’re struggling with motion sensor alerts, here are a few tips:
- Check for environmental triggers: Sunlight, wind, or even pets can cause false alerts.
- Adjust placement: Experiment with different angles and positions to find the sweet spot.
- Use companion devices: Pair your motion sensor with a camera to verify alerts before taking action.
Have you encountered similar issues with your motion sensors? How did you resolve them? I’d love to hear your experiences and tips!
