Solving Motion Sensor Issues in the Bathroom
I recently encountered an issue with my motion sensors in the bathroom, and I wanted to share my experience and solution with the community. I have two Aqara motion sensors installed, but after a few days of use, they stopped detecting motion. I suspect this is due to the steam and moisture from the shower affecting their performance.
After doing some research, I found that moisture can indeed interfere with the sensors’ ability to detect motion. I decided to look into more durable, waterproof alternatives. I came across some great options from brands like Wyze and Eufy, which are specifically designed to withstand high levels of humidity and moisture.
If you’re facing a similar issue, here are a few tips that might help:
  • Check the sensor’s IP rating: Ensure the sensor is rated for bathroom use (IP67 or higher).
  • Adjust the sensor’s position: Moving the sensor slightly away from direct steam or water spray can make a big difference.
  • Consider a waterproof cover: Some sensors can be protected with a waterproof housing to prevent moisture damage.
I ended up switching to a Wyze motion sensor, which has held up well so far. It’s important to note that while these sensors are more durable, they still need to be placed strategically to avoid direct exposure to water or steam.
If anyone has additional tips or experiences with waterproof motion sensors, I’d love to hear about them! Let’s keep improving our smart home setups together. :blush:
