I recently encountered a puzzling issue with my motion sensors, and I wanted to share my experience in case it helps others facing similar challenges. Here’s what happened:
I have a dozen WAPIRZ motion sensors installed throughout my home, and they’ve been a reliable part of my smart home setup. However, recently, I noticed that some of them were tripping or untripping unpredictably. To make matters more confusing, each sensor started showing a new device labeled as a ‘Nortek Temperature Sensor.’ This was perplexing because I hadn’t made any changes to my setup recently.
After some research, I discovered that Nortek is the parent company of Go Control, and there had been some firmware updates released for battery-powered devices. I wondered if these updates were causing the unexpected behavior. I reached out to the community for advice and tried several troubleshooting steps:
- Firmware Updates: I checked if my sensors were up to date. Unfortunately, some of them weren’t receiving the updates, and I couldn’t find clear release notes explaining the changes.
- Rebooting Devices: I reset the sensors and even removed and re-added them to my system, but the issue persisted.
- Exploring Workarounds: I tried pairing the sensors with different hubs and adjusting their sensitivity settings, but nothing seemed to resolve the problem.
The Turning Point: After days of troubleshooting, I stumbled upon a forum post suggesting that the firmware update might have altered how the sensors communicate. I decided to try a complete factory reset on one of the sensors, and to my surprise, it started working correctly again! Encouraged by this success, I applied the same solution to the other affected sensors.
Final Thoughts: While the issue was frustrating, it taught me the importance of staying updated with firmware changes and not hesitating to try a factory reset when troubleshooting. I’m grateful to the community for their support and insights. If anyone else is facing similar issues, I’d recommend checking for firmware updates and trying a factory reset as a potential solution.
Happy smart home tinkering! ![]()
