Recently, I encountered an issue with MQTT auto-discovery in Home Assistant after an update. My devices weren’t being detected, even though they were connected and sending messages. After some troubleshooting, I found the solution and thought I’d share it to help others facing the same problem.**The Issue:**After updating Home Assistant, my newly added devices weren’t showing up. MQTT Explorer confirmed the devices were sending messages, and Mosquitto logs showed successful connections. However, Home Assistant didn’t recognize them.**Troubleshooting Steps:**1. Checked Configuration: Ensured MQTT integration was correctly configured.2. Reflashed Devices: Tried reflashing a device with a different IP, but it didn’t resolve the issue.3. Updated Home Assistant: Upgraded to the latest version, but the problem persisted.4. Review Logs: Looked into Home Assistant logs for clues.The Solution:The problem was with the MQTT discovery configuration. I had to manually add the devices by specifying their discovery topics. Here’s how I did it:yamlmqtt: discovery_prefix: homeassistant discovery: enabled: true retain: true scan_interval: 60I also ensured that each device’s MQTT topic was correctly formatted. For example, for a Tasmota device:yamltasmota: discovery_prefix: tasmota retain: trueTips for New Users:- Understand MQTT Structure: Familiarize yourself with MQTT topics and how devices publish/subscribe.- Check Logs Regularly: Logs can provide invaluable insights into connection issues.- Community Resources: Don’t hesitate to ask for help in forums or communities. Someone has likely encountered the same issue.**Final Thoughts:**Home Assistant’s MQTT integration is powerful, but it requires careful configuration. Taking the time to understand how it works can save a lot of frustration. I hope this helps anyone struggling with similar issues. Happy automating! ![]()
