Hey everyone, I wanted to share my recent experience with MQTT JSON value conversion, which I found quite challenging but ultimately rewarding. I was trying to set up an automation where the trigger is a JSON payload, and I needed to extract a specific value as a string for a notification message. Initially, this seemed straightforward, but I ran into a snag when trying to pass the JSON value into the message parameter. The automation worked perfectly when the message was a fixed string, but it failed when I attempted to use the dynamic JSON value.
After some research and experimentation, I discovered that the issue was related to how the JSON value was being accessed and formatted. I realized that I needed to ensure the value was correctly extracted and converted into a string that the notification service could handle. I ended up using a combination of template conditions and string formatting within the automation configuration to achieve this. Here’s a snippet of what worked for me:
yaml
alias: ‘CallerID 1’
trigger:
platform: mqtt
topic: home/sip
condition:
condition: template
value_template: ‘{{ “incoming” == trigger.payload_json.status }}’
action:
service: notify.salatv_tv
data:
message: ‘{{ trigger.payload_json.callerID }}’
I also reached out to the community for advice, and someone suggested using the json4es filter to ensure proper JSON parsing. This filter helped me validate and correctly format the JSON payload, which was crucial for extracting the callerID value without any issues.
This experience taught me the importance of thorough testing and the value of community support when troubleshooting. It’s amazing how a small tweak in the configuration can make such a big difference in the functionality of your smart home setup. If anyone else is struggling with similar MQTT JSON issues, I highly recommend checking out the json4es filter and ensuring your templates are correctly formatted. Happy automating! ![]()
