Hey everyone,
I wanted to share my experience with a recurring issue I faced with my ST Arrival Sensors. It’s been quite the journey, but I think I’ve finally got a handle on it. Hopefully, this can help someone else avoid the frustration I went through!
The Problem:
I installed these sensors in my kids’ backpacks to track when they arrive home from school. It worked like a charm for the most part, but occasionally, the sensors would randomly ‘depart’ and then ‘arrive’ again almost instantly, even when the backpacks hadn’t moved. This was super annoying, and worse, it would trigger my SHM to disarm if I wasn’t home. It felt like a false alarm system gone wild!
What I Noticed:
- The sensors were placed near the back door, close to the hub, so there were no architectural barriers interfering.
- They worked flawlessly for real arrivals, with impressive range detection all the way to the sidewalk.
- The issue wasn’t related to range or signal strength.
The Mystery:
I couldn’t figure out why they were misfiring. It was perplexing because everything seemed to be in the right place and working as intended. I wondered if there was some kind of interference I wasn’t accounting for or if the sensors needed recalibration.
The Solution:
After some research and trial and error, I stumbled upon a rule setup that changed everything. I set up a rule where the sensor couldn’t detect an arrival unless it had been gone for at least 10 minutes. This simple adjustment eliminated the random misfires because it essentially ignored any rapid departures and arrivals that didn’t make sense in the real world.
How to Set It Up:
If you’re facing a similar issue, here’s how you can implement this fix:
- Go to your smart home platform’s rule editor.
- Create a new rule that monitors the arrival sensor.
- Set a condition where the sensor must have been away for a minimum of 10 minutes before it triggers an arrival notification.
- Save and test the rule.
The Outcome:
This tweak has been a game-changer. The false alarms are gone, and the system behaves as it should. It’s a small fix, but it makes a huge difference in reliability.
Lessons Learned:
- Sometimes, the simplest solutions are the most effective.
- Don’t hesitate to experiment with rules and conditions to fine-tune your system.
- Community forums are invaluable for troubleshooting and sharing solutions.
I hope this helps anyone else dealing with similar sensor issues. Happy automating! ![]()
