As someone who has been working with Netbotz 750 and sensor pods 150 for a while now, I wanted to share my recent experience with sensor disconnections. It started when I noticed occasional errors in the Netbotz system about sensors disconnecting, which required physically unplugging and replugging the sensors to restore functionality. This was frustrating, especially since we rely heavily on these sensors for our setup.
I first thought it might be a firmware issue, so I checked if there were any updates available for the sensor pods. Unfortunately, it seemed like the firmware was already up to date. Next, I considered whether the chain length could be a factor—after all, we have about 8 sensor pods connected in a single chain. I did some research and found that signal degradation over longer chains can sometimes cause disconnections.
To test this theory, I decided to try shortening the chain by splitting it into two separate chains with fewer sensors each. The results were almost immediate—disconnections became much less frequent. I also made sure to check for any potential interference from nearby devices, but it didn’t seem to be an issue in our setup.
This experience taught me the importance of carefully planning sensor chain configurations, especially when dealing with multiple devices. If you’re experiencing similar issues, I’d recommend checking your chain length and ensuring there’s minimal interference. Keeping firmware updated is also a good practice, even if it wasn’t the solution in this case.
I’d love to hear if anyone else has encountered similar problems or has other tips for maintaining reliable sensor connections. Happy tinkering! ![]()
