Hey everyone, I wanted to share a useful tip for those who might be struggling with connecting their smart devices. I recently faced an issue with my smart curtains where the second one wouldn’t connect after a firmware update. After some frustration and troubleshooting, I realized that resetting the device and ensuring a stable Wi-Fi connection was the key. Here’s what I did:
- Reset the Device: I unplugged the curtain, waited for a few minutes, and then plugged it back in. This helped reset any temporary glitches.
- Check Wi-Fi Strength: I moved the curtain closer to my router to ensure it had a strong signal. Sometimes, weak Wi-Fi can cause connection issues.
- Reboot the Router: I also restarted my router, which helped in establishing a fresh connection.
- Manual Setup: I used the app to manually add the device, following the on-screen instructions carefully.
These steps worked wonders, and now both my curtains are working seamlessly! If you’re facing similar issues, I hope this helps. Let me know if you have any questions or if there’s a better method you’ve tried. Happy smartening! ![]()
