Hey everyone, I wanted to share my experience with the Tapo C110 camera and how I managed to overcome an issue I encountered. It’s a great device, but I ran into some unexpected problems that I thought others might find helpful to hear about.
Initially, everything was working perfectly. The camera installation was straightforward, and I set up a simple automation to take photos whenever the motion sensor was triggered. The images were clear and sharp, and I even had them sent to my Telegram channel. It was a breeze to set up, and I was really impressed with the quality.
However, a day later, things took a turn. The photos started looking blurry and distorted. I hadn’t made any changes to the setup, so this was quite puzzling. I checked the camera settings, reset it, and even tried adjusting the timing delays in my automation, but nothing seemed to work consistently. It was frustrating because the camera had been performing so well initially.
After some research, I came across a suggestion to adjust the image settings on the camera itself. I played around with the resolution and compression settings, and to my delight, the issue started to resolve. It turns out that sometimes default settings aren’t the best fit for every environment, and tweaking them can make a world of difference.
I also modified my automation to include a short delay before taking the photo, which helped ensure the camera had time to focus properly. Here’s a snippet of the automation I ended up using:
yaml
alias: Photo on Motion
trigger:
- platform: state
entity_id: binary_sensor.c110_cam_motion
to: ‘on’
for: 2 seconds
action: - delay: 2 seconds
- service: camera.snapshot
data:
filename: /media/local/snapshot.jpg
This tweak made a significant improvement in the photo quality. The images are now consistently clear, and the automation works like a charm. I’m really happy with how it turned out!
This experience taught me the importance of experimenting with settings and not being afraid to adjust automations to fit specific needs. It’s also a reminder that sometimes, a minor tweak can lead to major improvements. I hope this helps anyone else who might be facing similar issues with their Tapo cameras or automations.
Happy automating! ![]()
