Hey everyone, I wanted to share a little victory I had with my vacuum cleaner. I’ve been using it for a while now, and it’s been a great helper around the house. However, there was one issue that was driving me a bit crazy—when I moved the vacuum to a different room with carpet flooring, it would dock with the charging station but then immediately undock and try again repeatedly. It was like a never-ending cycle, and it was frustrating to watch it drain its battery doing this over and over.
I decided to figure out what was going on. After some observation, I noticed that the charging dock, even when pressed against the baseboard, would tilt upwards slightly when the vacuum tried to dock. I realized this was because the carpet was attached to the nail strips at the edge of the wall, making the flooring under the charging dock uneven. The charging plates on the vacuum and the dock weren’t aligning properly because of this tilt.
I tried a few things, like adjusting the position of the dock and ensuring it was as flat as possible. But the issue persisted. Then, I had an idea—I placed a small object, about 3/4 of an inch thick, behind the charging dock, pushing it slightly away from the wall. This adjustment made the dock sit more firmly on the carpet and away from the uneven edge. Since making this change, the vacuum has been docking perfectly without any issues!
It’s a simple fix, but it made a huge difference. I think the manufacturer might need to look into improving the charging dock design for carpets, but in the meantime, this workaround has been a lifesaver for me. I’m curious to hear if others have encountered similar problems and what solutions they’ve come up with. Let’s share our experiences and tips!
Happy cleaning! ![]()
