Hey everyone! I wanted to share my experience with setting up an automation for my garage door. It’s been a bit of a learning curve, but I think I’ve got it figured out now.
I recently installed a smart garage door opener and wanted to set up an automation that would notify me whenever the door was opened or closed. The goal was to receive a single notification each time the door changed state. However, I ran into an issue where the system would send multiple notifications for a single action, which was pretty frustrating.
After some research and trial and error, I discovered that the problem was related to how the system was detecting the door’s state. The sensor was picking up multiple changes in the door’s position, leading to multiple notifications. To fix this, I adjusted the automation logic to only trigger the notification when the door’s state changed from one specific state to another, rather than on every small movement.
Here’s a quick breakdown of what I did:
- Identified the Trigger: I set the trigger to activate only when the door’s state changed from ‘closed’ to ‘open’ or vice versa.
- Added a Delay: I introduced a short delay in the automation to ensure that the system didn’t pick up any intermediate states during the door’s movement.
- Tested the Automation: I tested the setup multiple times to ensure that it only sent a single notification per action.
This adjustment worked perfectly! Now, I receive a clean, single notification each time the garage door opens or closes. It’s such a relief to have this automation working smoothly.
If anyone else is dealing with similar issues, I’d recommend checking your automation logic and considering adding delays or state-specific triggers. It can make a world of difference in how your smart home operates. Happy automating! ![]()
