I recently faced a puzzling issue with my Govee permanent outdoor lights, and I’m thrilled to share how I resolved it. After a power outage, the lights wouldn’t turn off using my Lutron Picos. Every press would toggle them on, but they stubbornly stayed on, as if ignoring the ‘off’ command. The logs showed a constant stream of ‘on’ and ‘off’ attempts, which was frustrating to say the least.The Problem: The lights were responding to the toggle command, but only in one direction. Pressing the button turned them on, but subsequent presses didn’t register the ‘off’ command. This left me manually turning them off through the device page each time, which was far from ideal.The Investigation: I started by checking the device logs and noticed a pattern: every ‘off’ command was immediately followed by an ‘on’ command. This suggested a communication issue between the Lutron Picos and the Govee lights. I wondered if the firmware was outdated or if there was a configuration error.The Solution: After some research, I discovered that updating the Govee app and ensuring the firmware was up-to-date could resolve such issues. I proceeded to:1. Update the Govee app to the latest version.2. Check for firmware updates on the outdoor lights through the app.3. Reset the Lutron Picos to ensure a clean connection.The Outcome: Post-update, the lights now respond perfectly to the toggle command. The issue was likely due to outdated firmware that didn’t handle the toggle commands correctly. Updating everything brought everything back to life, and the lights now function as intended.A Word of Thanks: I want to thank the supportive community forums where I found guidance. It’s amazing how a little troubleshooting and community support can turn a frustrating problem into a solved case. If anyone else is facing similar issues, I highly recommend checking for firmware updates and ensuring all connected devices are on the latest software versions.This experience reinforced my belief in the importance of regular maintenance and updates in a smart home setup. Here’s to a smoother and more enjoyable smart home experience for all!
