I recently purchased a pair of H5104 Wi-Fi temperature sensors, and I must say, the initial setup was a bit of a puzzle. While they worked perfectly with Bluetooth, the real goal was to connect them to my Wi-Fi so I could monitor temperatures remotely, especially when I’m not at home. Let me share my journey and solution in case anyone else is facing the same challenge.First, I tried the straightforward approach: placing the sensors near my router and following the manufacturer’s instructions. Unfortunately, they didn’t connect to my Wi-Fi network as expected. After some research, I discovered that the sensors might require a specific network setup. I decided to reset both sensors and ensure they were within close proximity to my router during the setup process.The breakthrough came when I realized the importance of the network password format. I had been using the standard password, but it turns out the sensors require the password to be in plain text without any special characters. After changing the password to a simpler format, the sensors connected seamlessly!Now, I can monitor the temperatures from anywhere, which is incredibly convenient. If you’re struggling with similar issues, here are a few tips:- Ensure the sensors are within 10 feet of your router during setup.- Use a plain text password without special characters.- Reset the sensors before attempting to connect them again.This experience taught me the importance of thorough research and patience when setting up new devices. It’s also a reminder that sometimes, the simplest solutions are the most effective. I hope this helps anyone else who’s trying to connect their H5104 sensors!
