Solving the Lock Bolt Auto-Lock Issue: A Step-by-Step Guide
I recently faced a frustrating issue with my Lock Bolt smart lock where it would occasionally attempt to auto-lock even though I had explicitly set Auto-Lock and Auto-Unlock to OFF. This was particularly annoying because my door doesn’t sit flush, meaning I have to manually pull it to lock, which often triggered the door jam alarm. After some research and troubleshooting, I found a reliable solution that might help others facing the same problem.
The Problem
The Lock Bolt was sporadically trying to auto-lock, even when I was explicitly managing the locking process manually. This was not only inconvenient but also a safety concern, as it could potentially lock me out if the auto-lock feature kicked in unexpectedly.
Troubleshooting Steps
  1. Reviewing Settings: I double-checked the settings in the Lock Bolt app to ensure Auto-Lock and Auto-Unlock were indeed turned off. They were, so the issue wasn’t a simple misconfiguration.
  2. Firmware Update: I checked for any available firmware updates for the Lock Bolt. Updating the firmware didn’t resolve the issue, but it was a necessary step to ensure I wasn’t missing any critical fixes.
  3. Resetting the Device: I performed a factory reset on the Lock Bolt. This process involved holding down the button until the LED started flashing, then following the app instructions to re-pair the device. Unfortunately, this didn’t solve the problem either.
  4. Testing the Door Mechanism: I manually tested the door to see if there was any physical obstruction or misalignment causing the lock to engage unexpectedly. Everything seemed to be in order mechanically.
  5. Disabling Cloud-Based Commands: After some research, I discovered that the Lock Bolt relies on cloud-based commands for certain operations. I decided to disable these cloud commands through the app settings to see if it would stop the auto-lock attempts. This turned out to be the key solution!
The Solution
By disabling cloud-based commands, I effectively took control of the locking mechanism away from the app and into my own hands. This means the Lock Bolt no longer attempts to auto-lock based on any external triggers or app commands. Instead, it relies solely on manual operation, which is exactly what I wanted.
Steps to Disable Cloud-Based Commands
  1. Open the Lock Bolt app.
  2. Navigate to the device settings for your specific lock.
  3. Look for an option labeled Cloud Commands or something similar.
  4. Disable this feature.
  5. Save your changes and test the lock to ensure it no longer attempts to auto-lock.
Conclusion
Disabling cloud-based commands was the game-changer for me. It’s a simple fix that restored control over my smart lock and eliminated the frustrating auto-lock attempts. If you’re experiencing similar issues with your Lock Bolt, I highly recommend trying this solution. It’s a minor adjustment that can make a significant difference in your smart home experience.
Let me know if you’ve tried this or if you’ve found other solutions to similar problems! Happy smart home tinkering! :rocket:
